Time Before: 0.00161 seconds
Time After: 0.00221 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00229 seconds
Time After: 0.00274 seconds
Time Before: 0.00304 seconds
Time After: 0.00317 seconds
Time Before: 0.00409 seconds
Time After: 0.00661 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00325 seconds
Time After: 0.01052 seconds
Time Taken: 0.00727 seconds
Time Before: 0.01256 seconds
Time After: 0.01280 seconds
Time Before: 0.01519 seconds
Time After: 0.01648 seconds
Time Before: 0.01191 seconds
Time After: 0.01666 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02357 seconds
Time After: 0.02373 seconds
Time Before: 0.02580 seconds
Time After: 0.02715 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.029377222061157
Time Before: 0.03055 seconds
Time After: 0.03088 seconds
Time Before: 0.03345 seconds
Time After: 0.03499 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=4000', badlocation = 1
Time Before: 0.04805 seconds
Time After: 0.04838 seconds
Memory Before: 4,288.008 KB
Memory After: 4,288.234 KB
Page generated in 0.047138214111328 seconds with 9 queries, spending 0.0083575248718262 doing MySQL queries and 0.038780689239502 doing PHP things.
