Time Before: 0.02417 seconds
Time After: 0.02958 seconds
Time Taken: 0.00541 seconds
Time Before: 0.02967 seconds
Time After: 0.03017 seconds
Time Before: 0.03045 seconds
Time After: 0.03062 seconds
Time Before: 0.03167 seconds
Time After: 0.03485 seconds
Time Taken: 0.00317 seconds
Time Before: 0.03070 seconds
Time After: 0.03924 seconds
Time Taken: 0.00854 seconds
Time Before: 0.04861 seconds
Time After: 0.04885 seconds
Time Before: 0.05255 seconds
Time After: 0.05391 seconds
Time Taken: 0.00136 seconds
Time Before: 0.04774 seconds
Time After: 0.05417 seconds
Time Taken: 0.00642 seconds
Time Before: 0.09701 seconds
Time After: 0.09718 seconds
Time Before: 0.11670 seconds
Time After: 0.11798 seconds
End call of global.php: 0.12060379981995
Time Before: 0.13182 seconds
Time After: 0.13199 seconds
Time Before: 0.13488 seconds
Time After: 0.13633 seconds
SET lastactivity = 1776721401, location = '/forums/private.php?do=newpm&explain=1&u=40060', badlocation = 1
Time Before: 0.15613 seconds
Time After: 0.15638 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.15476179122925 seconds with 9 queries, spending 0.0087764263153076 doing MySQL queries and 0.14598536491394 doing PHP things.
