Time Before: 0.02188 seconds
Time After: 0.02981 seconds
Time Taken: 0.00793 seconds
Time Before: 0.02989 seconds
Time After: 0.03031 seconds
Time Before: 0.03059 seconds
Time After: 0.03075 seconds
Time Before: 0.03165 seconds
Time After: 0.03398 seconds
Time Taken: 0.00234 seconds
Time Before: 0.03081 seconds
Time After: 0.03797 seconds
Time Taken: 0.00715 seconds
Time Before: 0.04749 seconds
Time After: 0.04792 seconds
Time Before: 0.04948 seconds
Time After: 0.05070 seconds
Time Before: 0.04681 seconds
Time After: 0.05090 seconds
Time Taken: 0.00408 seconds
Time Before: 0.08903 seconds
Time After: 0.08917 seconds
Time Before: 0.10665 seconds
Time After: 0.10791 seconds
End call of global.php: 0.10999989509583
Time Before: 0.11924 seconds
Time After: 0.11949 seconds
Time Before: 0.12303 seconds
Time After: 0.12453 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=40206'
Time Before: 0.14128 seconds
Time After: 0.14153 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.14036107063293 seconds with 9 queries, spending 0.0079789161682129 doing MySQL queries and 0.13238215446472 doing PHP things.
