Time Before: 0.00799 seconds
Time After: 0.00958 seconds
Time Taken: 0.00159 seconds
Time Before: 0.00969 seconds
Time After: 0.01015 seconds
Time Before: 0.01040 seconds
Time After: 0.01057 seconds
Time Before: 0.01145 seconds
Time After: 0.01404 seconds
Time Taken: 0.00258 seconds
Time Before: 0.01064 seconds
Time After: 0.01862 seconds
Time Taken: 0.00798 seconds
Time Before: 0.02295 seconds
Time After: 0.02333 seconds
Time Before: 0.02561 seconds
Time After: 0.02734 seconds
Time Taken: 0.00173 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02219 seconds
Time After: 0.02760 seconds
Time Taken: 0.00542 seconds
Memory After: 2,261.836 KB
Time Before: 0.03868 seconds
Time After: 0.03885 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10501 seconds
Time After: 0.10631 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.10866498947144
Time Before: 0.11235 seconds
Time After: 0.11252 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11531 seconds
Time After: 0.11679 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789116735, location = '/forums/private.php?do=newpm&explain=1&u=40255', badlocation = 1
Time Before: 0.13702 seconds
Time After: 0.13733 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.13560009002686 seconds with 9 queries, spending 0.0087649822235107 doing MySQL queries and 0.12683510780334 doing PHP things.
