Time Before: 0.01345 seconds
Time After: 0.02192 seconds
Time Taken: 0.00847 seconds
Time Before: 0.02202 seconds
Time After: 0.02361 seconds
Time Taken: 0.00159 seconds
Time Before: 0.02383 seconds
Time After: 0.02399 seconds
Time Before: 0.02488 seconds
Time After: 0.02815 seconds
Time Taken: 0.00326 seconds
Time Before: 0.02407 seconds
Time After: 0.03254 seconds
Time Before: 0.04084 seconds
Time After: 0.04174 seconds
Time Taken: 0.00090 seconds
Time Before: 0.04445 seconds
Time After: 0.04574 seconds
Time Before: 0.03959 seconds
Time After: 0.04598 seconds
Time Taken: 0.00639 seconds
Time Before: 0.07574 seconds
Time After: 0.07614 seconds
Time Before: 0.08585 seconds
Time After: 0.08720 seconds
Time Taken: 0.00135 seconds
Time Before: 0.09319 seconds
Time After: 0.09336 seconds
Time Before: 0.09575 seconds
Time After: 0.09720 seconds
UPDATE session SET lastactivity = 1788979142, location = '/forums/private.php?do=newpm&explain=1&u=40292' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.11498 seconds
Time After: 0.11526 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
