Time Before: 0.00788 seconds
Time After: 0.01001 seconds
Time Taken: 0.00213 seconds
Time Before: 0.01012 seconds
Time After: 0.01059 seconds
Time Before: 0.01083 seconds
Time After: 0.01099 seconds
Time Before: 0.01170 seconds
Time After: 0.01407 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01106 seconds
Time After: 0.01837 seconds
Time Taken: 0.00731 seconds
Time Before: 0.02170 seconds
Time After: 0.02210 seconds
Time Before: 0.02462 seconds
Time After: 0.02583 seconds
Time Before: 0.02103 seconds
Time After: 0.02607 seconds
Time Taken: 0.00504 seconds
Time Before: 0.04087 seconds
Time After: 0.04104 seconds
Time Before: 0.04648 seconds
Time After: 0.04772 seconds
End call of global.php: 0.049746036529541
Time Before: 0.05258 seconds
Time After: 0.05274 seconds
Time Before: 0.05509 seconds
Time After: 0.05692 seconds
Time Taken: 0.00183 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=40399', badlocation = 1
Time Before: 0.07255 seconds
Time After: 0.07277 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.071614027023315 seconds with 9 queries, spending 0.0082287788391113 doing MySQL queries and 0.063385248184204 doing PHP things.
