Time Before: 0.01742 seconds
Time After: 0.02307 seconds
Time Taken: 0.00565 seconds
Time Before: 0.02319 seconds
Time After: 0.02359 seconds
Time Before: 0.02384 seconds
Time After: 0.02397 seconds
Time Before: 0.02476 seconds
Time After: 0.02728 seconds
Time Taken: 0.00252 seconds
Time Before: 0.02403 seconds
Time After: 0.03086 seconds
Time Taken: 0.00683 seconds
Time Before: 0.03776 seconds
Time After: 0.03794 seconds
Time Before: 0.04078 seconds
Time After: 0.04202 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03716 seconds
Time After: 0.04222 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.719 KB
Time Before: 0.06717 seconds
Time After: 0.06730 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.39206 seconds
Time After: 0.39358 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.39567899703979
Time Before: 0.40390 seconds
Time After: 0.40407 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.40728 seconds
Time After: 0.40883 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=40469', badlocation = 1
Time Before: 0.42679 seconds
Time After: 0.42703 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.42573499679565 seconds with 9 queries, spending 0.0080809593200684 doing MySQL queries and 0.41765403747559 doing PHP things.
