Time Before: 0.03398 seconds
Time After: 0.04852 seconds
Time Taken: 0.01453 seconds
Time Before: 0.04864 seconds
Time After: 0.04908 seconds
Time Before: 0.04937 seconds
Time After: 0.04950 seconds
Time Before: 0.05032 seconds
Time After: 0.05304 seconds
Time Taken: 0.00272 seconds
Time Before: 0.04957 seconds
Time After: 0.05736 seconds
Time Taken: 0.00780 seconds
Time Before: 0.07188 seconds
Time After: 0.07227 seconds
Time Before: 0.07373 seconds
Time After: 0.07498 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.07111 seconds
Time After: 0.07524 seconds
Time Taken: 0.00414 seconds
Memory After: 2,261.836 KB
Time Before: 0.12958 seconds
Time After: 0.12972 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.15276 seconds
Time After: 0.15400 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.16760 seconds
Time After: 0.16775 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.17064 seconds
Time After: 0.17208 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788891588, location = '/forums/private.php?do=newpm&explain=1&u=40583' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.19514 seconds
Time After: 0.19541 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
