Time Before: 0.00233 seconds
Time After: 0.00299 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00309 seconds
Time After: 0.00360 seconds
Time Before: 0.00382 seconds
Time After: 0.00404 seconds
Time Before: 0.00489 seconds
Time After: 0.00728 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00412 seconds
Time After: 0.01193 seconds
Time Taken: 0.00781 seconds
Time Before: 0.01381 seconds
Time After: 0.01403 seconds
Time Before: 0.01653 seconds
Time After: 0.01773 seconds
Time Before: 0.01320 seconds
Time After: 0.01798 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02419 seconds
Time After: 0.02441 seconds
Time Before: 0.02663 seconds
Time After: 0.02791 seconds
End call of global.php: 0.031002998352051
Time Before: 0.03239 seconds
Time After: 0.03257 seconds
Time Before: 0.03467 seconds
Time After: 0.03615 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=40632'
Time Before: 0.04985 seconds
Time After: 0.05019 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048925161361694 seconds with 9 queries, spending 0.008037805557251 doing MySQL queries and 0.040887355804443 doing PHP things.
