Time Before: 0.02998 seconds
Time After: 0.03897 seconds
Time Taken: 0.00899 seconds
Time Before: 0.03907 seconds
Time After: 0.03949 seconds
Time Before: 0.03974 seconds
Time After: 0.03987 seconds
Time Before: 0.04067 seconds
Time After: 0.04257 seconds
Time Taken: 0.00190 seconds
Time Before: 0.03992 seconds
Time After: 0.04659 seconds
Time Taken: 0.00667 seconds
Time Before: 0.05433 seconds
Time After: 0.05473 seconds
Time Before: 0.05769 seconds
Time After: 0.05886 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05370 seconds
Time After: 0.05909 seconds
Time Taken: 0.00539 seconds
Time Before: 0.11383 seconds
Time After: 0.11397 seconds
Time Before: 0.13215 seconds
Time After: 0.13338 seconds
End call of global.php: 0.13528299331665
Time Before: 0.14497 seconds
Time After: 0.14511 seconds
Time Before: 0.14749 seconds
Time After: 0.14893 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=40633', badlocation = 1
Time Before: 0.16699 seconds
Time After: 0.16727 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.16571021080017 seconds with 9 queries, spending 0.0072598457336426 doing MySQL queries and 0.15845036506653 doing PHP things.
