Time Before: 0.00159 seconds
Time After: 0.00216 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00223 seconds
Time After: 0.00272 seconds
Time Before: 0.00297 seconds
Time After: 0.00313 seconds
Time Before: 0.00382 seconds
Time After: 0.00636 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00318 seconds
Time After: 0.00973 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01148 seconds
Time After: 0.01175 seconds
Time Before: 0.01393 seconds
Time After: 0.01519 seconds
Time Before: 0.01092 seconds
Time After: 0.01537 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02065 seconds
Time After: 0.02084 seconds
Time Before: 0.02274 seconds
Time After: 0.02407 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.025707006454468
Time Before: 0.02685 seconds
Time After: 0.02701 seconds
Time Before: 0.02892 seconds
Time After: 0.03034 seconds
SET lastactivity = 1776498492, location = '/forums/private.php?do=newpm&explain=1&u=40700', badlocation = 1
Time Before: 0.04252 seconds
Time After: 0.04290 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.041630983352661 seconds with 9 queries, spending 0.0082061290740967 doing MySQL queries and 0.033424854278564 doing PHP things.
