Time Before: 0.02210 seconds
Time After: 0.02949 seconds
Time Taken: 0.00739 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02960 seconds
Time After: 0.03007 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03031 seconds
Time After: 0.03045 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03113 seconds
Time After: 0.03371 seconds
Time Taken: 0.00258 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03051 seconds
Time After: 0.03839 seconds
Time Taken: 0.00788 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04300 seconds
Time After: 0.04335 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04601 seconds
Time After: 0.04731 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04229 seconds
Time After: 0.04754 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09599 seconds
Time After: 0.09611 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.39071 seconds
Time After: 0.39214 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.42020 seconds
Time After: 0.42054 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.42527 seconds
Time After: 0.42678 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772721484, location = '/forums/private.php?do=newpm&explain=1&u=40707', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.45348 seconds
Time After: 0.45586 seconds
Time Taken: 0.00238 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
