Time Before: 0.00197 seconds
Time After: 0.00251 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00262 seconds
Time After: 0.00310 seconds
Time Before: 0.00331 seconds
Time After: 0.00342 seconds
Time Before: 0.00413 seconds
Time After: 0.00658 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00347 seconds
Time After: 0.00999 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01177 seconds
Time After: 0.01217 seconds
Time Before: 0.01369 seconds
Time After: 0.01496 seconds
Time Before: 0.01116 seconds
Time After: 0.01513 seconds
Time Taken: 0.00397 seconds
Time Before: 0.02098 seconds
Time After: 0.02111 seconds
Time Before: 0.02339 seconds
Time After: 0.02466 seconds
Time Before: 0.02898 seconds
Time After: 0.02911 seconds
Time Before: 0.03114 seconds
Time After: 0.03278 seconds
Time Taken: 0.00164 seconds
UPDATE session SET lastactivity = 1788981199, location = '/forums/private.php?do=newpm&explain=1&u=4075', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04694 seconds
Time After: 0.04718 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
