Time Before: 0.00160 seconds
Time After: 0.00210 seconds
Time Before: 0.00217 seconds
Time After: 0.00283 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00313 seconds
Time After: 0.00330 seconds
Time Before: 0.00403 seconds
Time After: 0.00663 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00334 seconds
Time After: 0.01014 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01202 seconds
Time After: 0.01252 seconds
Time Before: 0.01474 seconds
Time After: 0.01601 seconds
Time Before: 0.01138 seconds
Time After: 0.01618 seconds
Time Taken: 0.00481 seconds
Time Before: 0.02207 seconds
Time After: 0.02223 seconds
Time Before: 0.02421 seconds
Time After: 0.02550 seconds
End call of global.php: 0.027143001556396
Time Before: 0.02831 seconds
Time After: 0.02848 seconds
Time Before: 0.03060 seconds
Time After: 0.03207 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=40978'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04606 seconds
Time After: 0.04635 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045160055160522 seconds with 9 queries, spending 0.0085780620574951 doing MySQL queries and 0.036581993103027 doing PHP things.
