Time Before: 0.00134 seconds
Time After: 0.00177 seconds
Time Before: 0.00184 seconds
Time After: 0.00234 seconds
Time Before: 0.00263 seconds
Time After: 0.00277 seconds
Time Before: 0.00377 seconds
Time After: 0.00621 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00285 seconds
Time After: 0.01167 seconds
Time Taken: 0.00882 seconds
Time Before: 0.01412 seconds
Time After: 0.01458 seconds
Time Before: 0.01724 seconds
Time After: 0.01844 seconds
Time Before: 0.01330 seconds
Time After: 0.01872 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02486 seconds
Time After: 0.02501 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"14.25,\";s:9:\"lastcheck\";i:1788953883;}', 1)Time Before: 0.03113 seconds
Time After: 0.03173 seconds
Time Taken: 0.00060 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03463 seconds
Time After: 0.03593 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.04135 seconds
Time After: 0.04152 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.04417 seconds
Time After: 0.04635 seconds
Time Taken: 0.00218 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1788953883, location = '/forums/private.php?do=newpm&explain=1&u=40982', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06195 seconds
Time After: 0.06231 seconds
Memory Before: 4,920.031 KB
Memory After: 4,920.242 KB
