Time Before: 0.00169 seconds
Time After: 0.00219 seconds
Time Before: 0.00226 seconds
Time After: 0.00290 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00314 seconds
Time After: 0.00326 seconds
Time Before: 0.00406 seconds
Time After: 0.00673 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00331 seconds
Time After: 0.01006 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01186 seconds
Time After: 0.01204 seconds
Time Before: 0.01505 seconds
Time After: 0.01626 seconds
Time Before: 0.01122 seconds
Time After: 0.01643 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02134 seconds
Time After: 0.02153 seconds
Time Before: 0.02392 seconds
Time After: 0.02580 seconds
Time Taken: 0.00188 seconds
End call of global.php: 0.027425050735474
Time Before: 0.02883 seconds
Time After: 0.02896 seconds
Time Before: 0.03100 seconds
Time After: 0.03244 seconds
SET lastactivity = 1789119712, location = '/forums/private.php?do=newpm&explain=1&u=40986', badlocation = 1
Time Before: 0.04739 seconds
Time After: 0.04767 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.046441078186035 seconds with 9 queries, spending 0.0087428092956543 doing MySQL queries and 0.037698268890381 doing PHP things.
