Time Before: 0.00498 seconds
Time After: 0.00599 seconds
Time Taken: 0.00101 seconds
Time Before: 0.00608 seconds
Time After: 0.00659 seconds
Time Before: 0.00691 seconds
Time After: 0.00704 seconds
Time Before: 0.00786 seconds
Time After: 0.01253 seconds
Time Taken: 0.00467 seconds
Time Before: 0.00711 seconds
Time After: 0.01813 seconds
Time Taken: 0.01102 seconds
Time Before: 0.02198 seconds
Time After: 0.02235 seconds
Time Before: 0.02473 seconds
Time After: 0.02593 seconds
Time Before: 0.02126 seconds
Time After: 0.02614 seconds
Time Taken: 0.00488 seconds
Time Before: 0.03727 seconds
Time After: 0.03739 seconds
Time Before: 0.04118 seconds
Time After: 0.04246 seconds
End call of global.php: 0.044254064559937
Time Before: 0.04593 seconds
Time After: 0.04606 seconds
Time Before: 0.04820 seconds
Time After: 0.04969 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1776458518, location = '/forums/private.php?do=newpm&explain=1&u=41072'
Time Before: 0.06810 seconds
Time After: 0.06836 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.066873073577881 seconds with 9 queries, spending 0.010180711746216 doing MySQL queries and 0.056692361831665 doing PHP things.
