Time Before: 0.00941 seconds
Time After: 0.01197 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01210 seconds
Time After: 0.01264 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01289 seconds
Time After: 0.01301 seconds
Time Before: 0.01389 seconds
Time After: 0.01673 seconds
Time Taken: 0.00284 seconds
Time Before: 0.01306 seconds
Time After: 0.02099 seconds
Time Taken: 0.00792 seconds
Time Before: 0.02575 seconds
Time After: 0.02623 seconds
Time Before: 0.02883 seconds
Time After: 0.03008 seconds
Time Before: 0.02488 seconds
Time After: 0.03032 seconds
Time Taken: 0.00544 seconds
Time Before: 0.04389 seconds
Time After: 0.04408 seconds
Time Before: 0.05296 seconds
Time After: 0.05425 seconds
Time Before: 0.05992 seconds
Time After: 0.06011 seconds
Time Before: 0.06276 seconds
Time After: 0.06428 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=41083' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.08105 seconds
Time After: 0.08129 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
