Time Before: 0.00157 seconds
Time After: 0.00224 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00231 seconds
Time After: 0.00278 seconds
Time Before: 0.00306 seconds
Time After: 0.00322 seconds
Time Before: 0.00411 seconds
Time After: 0.00655 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00330 seconds
Time After: 0.01091 seconds
Time Taken: 0.00761 seconds
Time Before: 0.01275 seconds
Time After: 0.01313 seconds
Time Before: 0.01575 seconds
Time After: 0.01692 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01214 seconds
Time After: 0.01710 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02236 seconds
Time After: 0.02251 seconds
Time Before: 0.02487 seconds
Time After: 0.02614 seconds
Time Before: 0.02993 seconds
Time After: 0.03040 seconds
Time Before: 0.03262 seconds
Time After: 0.03413 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=4110' WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.04846 seconds
Time After: 0.04876 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
