Time Before: 0.00927 seconds
Time After: 0.01169 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01177 seconds
Time After: 0.01237 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01258 seconds
Time After: 0.01271 seconds
Time Before: 0.01357 seconds
Time After: 0.01654 seconds
Time Taken: 0.00297 seconds
Time Before: 0.01277 seconds
Time After: 0.02076 seconds
Time Taken: 0.00799 seconds
Time Before: 0.02581 seconds
Time After: 0.02627 seconds
Time Before: 0.02938 seconds
Time After: 0.03124 seconds
Time Taken: 0.00186 seconds
Time Before: 0.02398 seconds
Time After: 0.03149 seconds
Time Taken: 0.00752 seconds
Time Before: 0.05335 seconds
Time After: 0.05351 seconds
Time Before: 0.05782 seconds
Time After: 0.05906 seconds
End call of global.php: 0.060874938964844
Time Before: 0.06382 seconds
Time After: 0.06399 seconds
Time Before: 0.06691 seconds
Time After: 0.06842 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1785479005, location = '/forums/private.php?do=newpm&explain=1&u=41114'
WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.08696 seconds
Time After: 0.08729 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.085823059082031 seconds with 9 queries, spending 0.0094301700592041 doing MySQL queries and 0.076392889022827 doing PHP things.
