Time Before: 0.01365 seconds
Time After: 0.01981 seconds
Time Taken: 0.00615 seconds
Time Before: 0.01991 seconds
Time After: 0.02039 seconds
Time Before: 0.02065 seconds
Time After: 0.02081 seconds
Time Before: 0.02151 seconds
Time After: 0.02387 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02086 seconds
Time After: 0.02806 seconds
Time Taken: 0.00719 seconds
Time Before: 0.03498 seconds
Time After: 0.03539 seconds
Time Before: 0.03686 seconds
Time After: 0.03804 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03426 seconds
Time After: 0.03826 seconds
Time Taken: 0.00401 seconds
Time Before: 0.06440 seconds
Time After: 0.06455 seconds
Time Before: 0.07535 seconds
Time After: 0.07656 seconds
End call of global.php: 0.078625917434692
Time Before: 0.08602 seconds
Time After: 0.08620 seconds
Time Before: 0.08854 seconds
Time After: 0.09000 seconds
SET lastactivity = 1785429580, location = '/forums/private.php?do=newpm&explain=1&u=4115', badlocation = 1
Time Before: 0.10788 seconds
Time After: 0.10815 seconds
Memory Before: 4,288.563 KB
Memory After: 4,288.773 KB
Page generated in 0.10681104660034 seconds with 9 queries, spending 0.0078468322753906 doing MySQL queries and 0.098964214324951 doing PHP things.
