Time Before: 0.00206 seconds
Time After: 0.00260 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00271 seconds
Time After: 0.00331 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00369 seconds
Time After: 0.00385 seconds
Time Before: 0.00460 seconds
Time After: 0.00750 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00393 seconds
Time After: 0.01112 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01303 seconds
Time After: 0.01369 seconds
Time Taken: 0.00066 seconds
Time Before: 0.01628 seconds
Time After: 0.01758 seconds
Time Before: 0.01238 seconds
Time After: 0.01777 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02505 seconds
Time After: 0.02521 seconds
Time Before: 0.03005 seconds
Time After: 0.03135 seconds
Time Before: 0.03522 seconds
Time After: 0.03540 seconds
Time Before: 0.03828 seconds
Time After: 0.03979 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=41182' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05662 seconds
Time After: 0.05688 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
