Time Before: 0.00181 seconds
Time After: 0.00228 seconds
Time Before: 0.00235 seconds
Time After: 0.00284 seconds
Time Before: 0.00305 seconds
Time After: 0.00318 seconds
Time Before: 0.00383 seconds
Time After: 0.00609 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00322 seconds
Time After: 0.01082 seconds
Time Taken: 0.00760 seconds
Time Before: 0.01408 seconds
Time After: 0.01455 seconds
Time Before: 0.01696 seconds
Time After: 0.01816 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01236 seconds
Time After: 0.01834 seconds
Time Taken: 0.00598 seconds
Memory After: 2,261.719 KB
Time Before: 0.02427 seconds
Time After: 0.02444 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02617 seconds
Time After: 0.02739 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.029002904891968
Time Before: 0.03010 seconds
Time After: 0.03027 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03236 seconds
Time After: 0.03385 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=41194'
Time Before: 0.04649 seconds
Time After: 0.04690 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.045602798461914 seconds with 9 queries, spending 0.0079967975616455 doing MySQL queries and 0.037606000900269 doing PHP things.
