Time Before: 0.02321 seconds
Time After: 0.03231 seconds
Time Taken: 0.00910 seconds
Time Before: 0.03242 seconds
Time After: 0.03297 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03326 seconds
Time After: 0.03340 seconds
Time Before: 0.03432 seconds
Time After: 0.03662 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03348 seconds
Time After: 0.04131 seconds
Time Taken: 0.00783 seconds
Time Before: 0.04915 seconds
Time After: 0.04971 seconds
Time Before: 0.05215 seconds
Time After: 0.05340 seconds
Time Before: 0.04812 seconds
Time After: 0.05363 seconds
Time Taken: 0.00550 seconds
Time Before: 0.09432 seconds
Time After: 0.09452 seconds
Time Before: 0.11255 seconds
Time After: 0.11382 seconds
Time Before: 0.12385 seconds
Time After: 0.12405 seconds
Time Before: 0.12651 seconds
Time After: 0.12797 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=41229', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.14503 seconds
Time After: 0.14531 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
