Time Before: 0.02156 seconds
Time After: 0.02964 seconds
Time Taken: 0.00807 seconds
Time Before: 0.02977 seconds
Time After: 0.03022 seconds
Time Before: 0.03051 seconds
Time After: 0.03063 seconds
Time Before: 0.03152 seconds
Time After: 0.03440 seconds
Time Taken: 0.00289 seconds
Time Before: 0.03069 seconds
Time After: 0.03872 seconds
Time Taken: 0.00803 seconds
Time Before: 0.04876 seconds
Time After: 0.04900 seconds
Time Before: 0.05058 seconds
Time After: 0.05180 seconds
Time Before: 0.04806 seconds
Time After: 0.05202 seconds
Time Taken: 0.00396 seconds
Time Before: 0.09238 seconds
Time After: 0.09252 seconds
Time Before: 0.54202 seconds
Time After: 0.54367 seconds
Time Taken: 0.00165 seconds
End call of global.php: 0.5460090637207
Time Before: 0.55232 seconds
Time After: 0.55248 seconds
Time Before: 0.55524 seconds
Time After: 0.55669 seconds
SET lastactivity = 1782992074, location = '/forums/private.php?do=newpm&explain=1&u=41254', badlocation = 1
Time Before: 0.57576 seconds
Time After: 0.57600 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.57430505752563 seconds with 9 queries, spending 0.0085635185241699 doing MySQL queries and 0.56574153900146 doing PHP things.
