Time Before: 0.01235 seconds
Time After: 0.01760 seconds
Time Taken: 0.00525 seconds
Time Before: 0.01770 seconds
Time After: 0.01812 seconds
Time Before: 0.01836 seconds
Time After: 0.01849 seconds
Time Before: 0.01926 seconds
Time After: 0.02137 seconds
Time Taken: 0.00211 seconds
Time Before: 0.01855 seconds
Time After: 0.02573 seconds
Time Taken: 0.00718 seconds
Time Before: 0.03215 seconds
Time After: 0.03257 seconds
Time Before: 0.03579 seconds
Time After: 0.03697 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03142 seconds
Time After: 0.03717 seconds
Time Taken: 0.00575 seconds
Time Before: 0.05905 seconds
Time After: 0.05918 seconds
Time Before: 0.07173 seconds
Time After: 0.07294 seconds
End call of global.php: 0.075637817382812
Time Before: 0.08086 seconds
Time After: 0.08100 seconds
Time Before: 0.08353 seconds
Time After: 0.08496 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=41341'
Time Before: 0.10498 seconds
Time After: 0.10527 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.10395884513855 seconds with 9 queries, spending 0.0074527263641357 doing MySQL queries and 0.096506118774414 doing PHP things.
