Time Before: 0.00893 seconds
Time After: 0.01181 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01192 seconds
Time After: 0.01228 seconds
Time Before: 0.01249 seconds
Time After: 0.01261 seconds
Time Before: 0.01336 seconds
Time After: 0.01571 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01268 seconds
Time After: 0.01964 seconds
Time Taken: 0.00696 seconds
Time Before: 0.02454 seconds
Time After: 0.02517 seconds
Time Taken: 0.00063 seconds
Time Before: 0.02794 seconds
Time After: 0.02912 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02387 seconds
Time After: 0.02933 seconds
Time Taken: 0.00546 seconds
Time Before: 0.04327 seconds
Time After: 0.04341 seconds
Time Before: 0.04915 seconds
Time After: 0.05057 seconds
End call of global.php: 0.052640199661255
Time Before: 0.05669 seconds
Time After: 0.05693 seconds
Time Before: 0.05942 seconds
Time After: 0.06084 seconds
SET lastactivity = 1789103928, location = '/forums/private.php?do=newpm&explain=1&u=41447'
Time Before: 0.07666 seconds
Time After: 0.07695 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.075656175613403 seconds with 9 queries, spending 0.0081307888031006 doing MySQL queries and 0.067525386810303 doing PHP things.
