Time Before: 0.01602 seconds
Time After: 0.02330 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02341 seconds
Time After: 0.02384 seconds
Time Before: 0.02407 seconds
Time After: 0.02430 seconds
Time Before: 0.02508 seconds
Time After: 0.02747 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02438 seconds
Time After: 0.03202 seconds
Time Taken: 0.00765 seconds
Time Before: 0.03922 seconds
Time After: 0.03962 seconds
Time Before: 0.04245 seconds
Time After: 0.04361 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03846 seconds
Time After: 0.04383 seconds
Time Taken: 0.00537 seconds
Time Before: 0.06980 seconds
Time After: 0.07002 seconds
Time Before: 0.08942 seconds
Time After: 0.09071 seconds
End call of global.php: 0.09348201751709
Time Before: 0.10143 seconds
Time After: 0.10158 seconds
Time Before: 0.10524 seconds
Time After: 0.10671 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=41594', badlocation = 1
Time Before: 0.12435 seconds
Time After: 0.12458 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.12335014343262 seconds with 9 queries, spending 0.0079705715179443 doing MySQL queries and 0.11537957191467 doing PHP things.
