Time Before: 0.00151 seconds
Time After: 0.00197 seconds
Time Before: 0.00203 seconds
Time After: 0.00250 seconds
Time Before: 0.00274 seconds
Time After: 0.00286 seconds
Time Before: 0.00348 seconds
Time After: 0.00566 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00291 seconds
Time After: 0.00906 seconds
Time Taken: 0.00615 seconds
Time Before: 0.01079 seconds
Time After: 0.01115 seconds
Time Before: 0.01395 seconds
Time After: 0.01508 seconds
Time Taken: 0.00113 seconds
Time Before: 0.01020 seconds
Time After: 0.01525 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02245 seconds
Time After: 0.02260 seconds
Time Before: 0.02505 seconds
Time After: 0.02798 seconds
Time Taken: 0.00293 seconds
Time Before: 0.03141 seconds
Time After: 0.03156 seconds
Time Before: 0.03408 seconds
Time After: 0.03553 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=41707', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05269 seconds
Time After: 0.05291 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
