Time Before: 0.00200 seconds
Time After: 0.00251 seconds
Time Before: 0.00258 seconds
Time After: 0.00309 seconds
Time Before: 0.00332 seconds
Time After: 0.00346 seconds
Time Before: 0.00412 seconds
Time After: 0.00851 seconds
Time Taken: 0.00439 seconds
Time Before: 0.00351 seconds
Time After: 0.01329 seconds
Time Taken: 0.00978 seconds
Time Before: 0.01520 seconds
Time After: 0.01560 seconds
Time Before: 0.01691 seconds
Time After: 0.01811 seconds
Time Before: 0.01462 seconds
Time After: 0.01828 seconds
Time Taken: 0.00366 seconds
Time Before: 0.02324 seconds
Time After: 0.02339 seconds
Time Before: 0.02602 seconds
Time After: 0.02737 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03187 seconds
Time After: 0.03205 seconds
Time Before: 0.03427 seconds
Time After: 0.03574 seconds
UPDATE session SET lastactivity = 1788874154, location = '/forums/private.php?do=newpm&explain=1&u=41720' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04855 seconds
Time After: 0.04891 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
