Time Before: 0.00147 seconds
Time After: 0.00205 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00212 seconds
Time After: 0.00277 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00310 seconds
Time After: 0.00330 seconds
Time Before: 0.00420 seconds
Time After: 0.00712 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00339 seconds
Time After: 0.01183 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01415 seconds
Time After: 0.01443 seconds
Time Before: 0.01670 seconds
Time After: 0.01795 seconds
Time Before: 0.01352 seconds
Time After: 0.01812 seconds
Time Taken: 0.00460 seconds
Time Before: 0.02323 seconds
Time After: 0.02341 seconds
Time Before: 0.02561 seconds
Time After: 0.02686 seconds
End call of global.php: 0.028563022613525
Time Before: 0.03079 seconds
Time After: 0.03096 seconds
Time Before: 0.03337 seconds
Time After: 0.03482 seconds
SET lastactivity = 1782957067, location = '/forums/private.php?do=newpm&explain=1&u=41837'
Time Before: 0.04809 seconds
Time After: 0.04837 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.047144889831543 seconds with 9 queries, spending 0.008638858795166 doing MySQL queries and 0.038506031036377 doing PHP things.
