Time Before: 0.00210 seconds
Time After: 0.00322 seconds
Time Taken: 0.00113 seconds
Time Before: 0.00329 seconds
Time After: 0.00377 seconds
Time Before: 0.00397 seconds
Time After: 0.00414 seconds
Time Before: 0.00480 seconds
Time After: 0.00696 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00419 seconds
Time After: 0.01040 seconds
Time Taken: 0.00621 seconds
Time Before: 0.01286 seconds
Time After: 0.01320 seconds
Time Before: 0.01538 seconds
Time After: 0.01657 seconds
Time Before: 0.01229 seconds
Time After: 0.01675 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02300 seconds
Time After: 0.02312 seconds
Time Before: 1.59286 seconds
Time After: 1.59430 seconds
End call of global.php: 1.5972990989685
Time Before: 1.60029 seconds
Time After: 1.60044 seconds
Time Before: 1.60334 seconds
Time After: 1.60481 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=41929'
Time Before: 1.62280 seconds
Time After: 1.62313 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 1.6217510700226 seconds with 9 queries, spending 0.0078582763671875 doing MySQL queries and 1.6138927936554 doing PHP things.
