Time Before: 0.00945 seconds
Time After: 0.01255 seconds
Time Taken: 0.00311 seconds
Time Before: 0.01264 seconds
Time After: 0.01306 seconds
Time Before: 0.01331 seconds
Time After: 0.01345 seconds
Time Before: 0.01444 seconds
Time After: 0.01664 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01353 seconds
Time After: 0.02218 seconds
Time Taken: 0.00865 seconds
Time Before: 0.02831 seconds
Time After: 0.02881 seconds
Time Before: 0.03203 seconds
Time After: 0.03323 seconds
Time Before: 0.02762 seconds
Time After: 0.03345 seconds
Time Taken: 0.00583 seconds
Time Before: 0.05627 seconds
Time After: 0.05641 seconds
Time Before: 0.06608 seconds
Time After: 0.06735 seconds
End call of global.php: 0.069644927978516
Time Before: 0.07407 seconds
Time After: 0.07426 seconds
Time Before: 0.07715 seconds
Time After: 0.07860 seconds
SET lastactivity = 1783167421, location = '/forums/private.php?do=newpm&explain=1&u=42039'
Time Before: 0.09524 seconds
Time After: 0.09568 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.094332933425903 seconds with 9 queries, spending 0.0079262256622314 doing MySQL queries and 0.086406707763672 doing PHP things.
