Time Before: 0.00155 seconds
Time After: 0.00200 seconds
Time Before: 0.00206 seconds
Time After: 0.00246 seconds
Time Before: 0.00269 seconds
Time After: 0.00281 seconds
Time Before: 0.00351 seconds
Time After: 0.00680 seconds
Time Taken: 0.00330 seconds
Time Before: 0.00286 seconds
Time After: 0.01044 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01227 seconds
Time After: 0.01513 seconds
Time Taken: 0.00286 seconds
Time Before: 0.01772 seconds
Time After: 0.01891 seconds
Time Before: 0.01164 seconds
Time After: 0.01911 seconds
Time Taken: 0.00748 seconds
Time Before: 0.02438 seconds
Time After: 0.02452 seconds
Time Before: 0.02631 seconds
Time After: 0.02750 seconds
Time Before: 0.03065 seconds
Time After: 0.03077 seconds
Time Before: 0.03298 seconds
Time After: 0.03439 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=42073', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04838 seconds
Time After: 0.05194 seconds
Time Taken: 0.00356 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
