Time Before: 0.02235 seconds
Time After: 0.03472 seconds
Time Taken: 0.01237 seconds
Time Before: 0.03480 seconds
Time After: 0.03528 seconds
Time Before: 0.03552 seconds
Time After: 0.03570 seconds
Time Before: 0.03645 seconds
Time After: 0.03886 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03575 seconds
Time After: 0.04273 seconds
Time Taken: 0.00697 seconds
Time Before: 0.05499 seconds
Time After: 0.05570 seconds
Time Taken: 0.00072 seconds
Time Before: 0.05814 seconds
Time After: 0.05935 seconds
Time Before: 0.05412 seconds
Time After: 0.05953 seconds
Time Taken: 0.00541 seconds
Time Before: 0.09074 seconds
Time After: 0.09090 seconds
Time Before: 0.11578 seconds
Time After: 0.11708 seconds
End call of global.php: 0.11931705474854
Time Before: 0.13471 seconds
Time After: 0.13493 seconds
Time Before: 0.13780 seconds
Time After: 0.13929 seconds
SET lastactivity = 1776780979, location = '/forums/private.php?do=newpm&explain=1&u=42164', badlocation = 1
Time Before: 0.15947 seconds
Time After: 0.15994 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.15839409828186 seconds with 9 queries, spending 0.0086491107940674 doing MySQL queries and 0.14974498748779 doing PHP things.
