Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00240 seconds
Time Before: 0.00266 seconds
Time After: 0.00277 seconds
Time Before: 0.00367 seconds
Time After: 0.00635 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00287 seconds
Time After: 0.01122 seconds
Time Taken: 0.00835 seconds
Time Before: 0.01380 seconds
Time After: 0.01423 seconds
Time Before: 0.01765 seconds
Time After: 0.01887 seconds
Time Before: 0.01307 seconds
Time After: 0.01913 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02954 seconds
Time After: 0.02967 seconds
Time Before: 0.03153 seconds
Time After: 0.03289 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.034647941589355
Time Before: 0.03628 seconds
Time After: 0.03647 seconds
Time Before: 0.03972 seconds
Time After: 0.04118 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=42191'
Time Before: 0.05780 seconds
Time After: 0.05807 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.056864976882935 seconds with 9 queries, spending 0.0082697868347168 doing MySQL queries and 0.048595190048218 doing PHP things.
