Time Before: 0.01976 seconds
Time After: 0.03115 seconds
Time Taken: 0.01139 seconds
Time Before: 0.03128 seconds
Time After: 0.03172 seconds
Time Before: 0.03196 seconds
Time After: 0.03211 seconds
Time Before: 0.03298 seconds
Time After: 0.03522 seconds
Time Taken: 0.00224 seconds
Time Before: 0.03220 seconds
Time After: 0.04041 seconds
Time Taken: 0.00822 seconds
Time Before: 0.05218 seconds
Time After: 0.05269 seconds
Time Before: 0.05551 seconds
Time After: 0.05672 seconds
Time Before: 0.05146 seconds
Time After: 0.05696 seconds
Time Taken: 0.00550 seconds
Time Before: 0.09524 seconds
Time After: 0.09569 seconds
Time Before: 0.12333 seconds
Time After: 0.12456 seconds
End call of global.php: 0.12683892250061
Time Before: 0.13732 seconds
Time After: 0.13748 seconds
Time Before: 0.14023 seconds
Time After: 0.14174 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1783040993, location = '/forums/private.php?do=newpm&explain=1&u=42216'
Time Before: 0.16489 seconds
Time After: 0.16530 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.16387891769409 seconds with 9 queries, spending 0.0082998275756836 doing MySQL queries and 0.15557909011841 doing PHP things.
