Time Before: 0.03029 seconds
Time After: 0.03676 seconds
Time Taken: 0.00647 seconds
Time Before: 0.03687 seconds
Time After: 0.03763 seconds
Time Taken: 0.00076 seconds
Time Before: 0.03786 seconds
Time After: 0.03799 seconds
Time Before: 0.03882 seconds
Time After: 0.04161 seconds
Time Taken: 0.00279 seconds
Time Before: 0.03806 seconds
Time After: 0.04708 seconds
Time Taken: 0.00902 seconds
Time Before: 0.05412 seconds
Time After: 0.05453 seconds
Time Before: 0.05761 seconds
Time After: 0.05891 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05343 seconds
Time After: 0.05915 seconds
Time Taken: 0.00572 seconds
Memory After: 2,261.719 KB
Time Before: 0.10601 seconds
Time After: 0.10632 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.12833 seconds
Time After: 0.12964 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.13153409957886
Time Before: 0.14206 seconds
Time After: 0.14224 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14468 seconds
Time After: 0.14613 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=42247', badlocation = 1
Time Before: 0.16540 seconds
Time After: 0.16569 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.16427111625671 seconds with 9 queries, spending 0.0089175701141357 doing MySQL queries and 0.15535354614258 doing PHP things.
