Time Before: 0.00143 seconds
Time After: 0.00198 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00205 seconds
Time After: 0.00260 seconds
Time Before: 0.00284 seconds
Time After: 0.00294 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00358 seconds
Time After: 0.00574 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00299 seconds
Time After: 0.00920 seconds
Time Taken: 0.00621 seconds
Time Before: 0.01154 seconds
Time After: 0.01197 seconds
Time Before: 0.01496 seconds
Time After: 0.01631 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01087 seconds
Time After: 0.01648 seconds
Time Taken: 0.00561 seconds
Memory After: 2,261.719 KB
Time Before: 0.02222 seconds
Time After: 0.02234 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02453 seconds
Time After: 0.02624 seconds
Time Taken: 0.00171 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.027987957000732
Time Before: 0.02937 seconds
Time After: 0.02951 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03164 seconds
Time After: 0.03308 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=42310', badlocation = 1
Time Before: 0.04546 seconds
Time After: 0.04579 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.044538974761963 seconds with 9 queries, spending 0.0083403587341309 doing MySQL queries and 0.036198616027832 doing PHP things.
