Time Before: 0.00130 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00234 seconds
Time Before: 0.00256 seconds
Time After: 0.00270 seconds
Time Before: 0.00345 seconds
Time After: 0.00617 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00275 seconds
Time After: 0.00960 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01149 seconds
Time After: 0.01188 seconds
Time Before: 0.01430 seconds
Time After: 0.01557 seconds
Time Before: 0.01087 seconds
Time After: 0.01577 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02115 seconds
Time After: 0.02133 seconds
Time Before: 0.02370 seconds
Time After: 0.02496 seconds
End call of global.php: 0.027050018310547
Time Before: 0.02857 seconds
Time After: 0.02874 seconds
Time Before: 0.03164 seconds
Time After: 0.03310 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=42432', badlocation = 1
Time Before: 0.04921 seconds
Time After: 0.04951 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.04826283454895 seconds with 9 queries, spending 0.0083887577056885 doing MySQL queries and 0.039874076843262 doing PHP things.
