Time Before: 0.00158 seconds
Time After: 0.00221 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00228 seconds
Time After: 0.00264 seconds
Time Before: 0.00281 seconds
Time After: 0.00294 seconds
Time Before: 0.00359 seconds
Time After: 0.00574 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00299 seconds
Time After: 0.00923 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01153 seconds
Time After: 0.01188 seconds
Time Before: 0.01422 seconds
Time After: 0.01546 seconds
Time Before: 0.01075 seconds
Time After: 0.01571 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02177 seconds
Time After: 0.02191 seconds
Time Before: 0.02417 seconds
Time After: 0.02540 seconds
End call of global.php: 0.027143955230713
Time Before: 0.02868 seconds
Time After: 0.02880 seconds
Time Before: 0.03076 seconds
Time After: 0.03214 seconds
Time Taken: 0.00138 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=42480', badlocation = 1
Time Before: 0.04447 seconds
Time After: 0.08179 seconds
Time Taken: 0.03732 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043555974960327 seconds with 9 queries, spending 0.044416189193726 doing MySQL queries and -0.00086021423339844 doing PHP things.
