Time Before: 0.00155 seconds
Time After: 0.00210 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00217 seconds
Time After: 0.00266 seconds
Time Before: 0.00301 seconds
Time After: 0.00317 seconds
Time Before: 0.00391 seconds
Time After: 0.00664 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00323 seconds
Time After: 0.01010 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01189 seconds
Time After: 0.01244 seconds
Time Before: 0.01472 seconds
Time After: 0.01604 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01134 seconds
Time After: 0.01622 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02120 seconds
Time After: 0.02137 seconds
Time Before: 0.02351 seconds
Time After: 0.02483 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.026471138000488
Time Before: 0.02772 seconds
Time After: 0.02787 seconds
Time Before: 0.02991 seconds
Time After: 0.03142 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=42521'
Time Before: 0.04374 seconds
Time After: 0.04410 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.042862176895142 seconds with 9 queries, spending 0.0087721347808838 doing MySQL queries and 0.034090042114258 doing PHP things.
