Time Before: 0.00331 seconds
Time After: 0.00582 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00590 seconds
Time After: 0.00643 seconds
Time Before: 0.00675 seconds
Time After: 0.00692 seconds
Time Before: 0.00775 seconds
Time After: 0.01035 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00700 seconds
Time After: 0.01467 seconds
Time Taken: 0.00767 seconds
Time Before: 0.01816 seconds
Time After: 0.01856 seconds
Time Before: 0.02112 seconds
Time After: 0.02233 seconds
Time Before: 0.01751 seconds
Time After: 0.02252 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02963 seconds
Time After: 0.02975 seconds
Time Before: 0.03405 seconds
Time After: 0.03527 seconds
End call of global.php: 0.036972999572754
Time Before: 0.03961 seconds
Time After: 0.03973 seconds
Time Before: 0.04170 seconds
Time After: 0.04319 seconds
SET lastactivity = 1789055656, location = '/forums/private.php?do=newpm&explain=1&u=42542', badlocation = 1
Time Before: 0.05619 seconds
Time After: 0.05641 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.055284023284912 seconds with 9 queries, spending 0.0080797672271729 doing MySQL queries and 0.047204256057739 doing PHP things.
