Time Before: 0.02069 seconds
Time After: 0.02584 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02594 seconds
Time After: 0.02644 seconds
Time Before: 0.02671 seconds
Time After: 0.02684 seconds
Time Before: 0.02772 seconds
Time After: 0.03002 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02692 seconds
Time After: 0.03395 seconds
Time Taken: 0.00703 seconds
Time Before: 0.04195 seconds
Time After: 0.04237 seconds
Time Before: 0.04480 seconds
Time After: 0.04625 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04131 seconds
Time After: 0.04646 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.836 KB
Time Before: 0.07107 seconds
Time After: 0.07120 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08938 seconds
Time After: 0.09064 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10240 seconds
Time After: 0.10260 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10556 seconds
Time After: 0.10701 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788958011, location = '/forums/private.php?do=newpm&explain=1&u=42547' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12432 seconds
Time After: 0.12464 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
