Time Before: 0.00153 seconds
Time After: 0.00206 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00213 seconds
Time After: 0.00256 seconds
Time Before: 0.00275 seconds
Time After: 0.00291 seconds
Time Before: 0.00379 seconds
Time After: 0.00636 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00296 seconds
Time After: 0.01146 seconds
Time Taken: 0.00851 seconds
Time Before: 0.01357 seconds
Time After: 0.01413 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01732 seconds
Time After: 0.01853 seconds
Time Before: 0.01273 seconds
Time After: 0.01880 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02632 seconds
Time After: 0.02646 seconds
Time Before: 0.02882 seconds
Time After: 0.03008 seconds
End call of global.php: 0.032840967178345
Time Before: 0.03456 seconds
Time After: 0.03472 seconds
Time Before: 0.03804 seconds
Time After: 0.03958 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=4271'
Time Before: 0.05930 seconds
Time After: 0.05962 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.057987928390503 seconds with 9 queries, spending 0.0083408355712891 doing MySQL queries and 0.049647092819214 doing PHP things.
