Time Before: 0.00174 seconds
Time After: 0.00235 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00246 seconds
Time After: 0.00308 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00332 seconds
Time After: 0.00349 seconds
Time Before: 0.00412 seconds
Time After: 0.00712 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00354 seconds
Time After: 0.01174 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01372 seconds
Time After: 0.01394 seconds
Time Before: 0.01646 seconds
Time After: 0.01776 seconds
Time Before: 0.01314 seconds
Time After: 0.01794 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02404 seconds
Time After: 0.02419 seconds
Time Before: 0.02662 seconds
Time After: 0.02791 seconds
End call of global.php: 0.030700922012329
Time Before: 0.03223 seconds
Time After: 0.03243 seconds
Time Before: 0.03529 seconds
Time After: 0.03673 seconds
SET lastactivity = 1783119578, location = '/forums/private.php?do=newpm&explain=1&u=42812', badlocation = 1
Time Before: 0.05046 seconds
Time After: 0.05078 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.049203872680664 seconds with 9 queries, spending 0.0087180137634277 doing MySQL queries and 0.040485858917236 doing PHP things.
