Time Before: 0.00216 seconds
Time After: 0.00279 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00289 seconds
Time After: 0.00332 seconds
Time Before: 0.00360 seconds
Time After: 0.00374 seconds
Time Before: 0.00457 seconds
Time After: 0.00671 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00382 seconds
Time After: 0.01190 seconds
Time Taken: 0.00808 seconds
Time Before: 0.01377 seconds
Time After: 0.01420 seconds
Time Before: 0.01736 seconds
Time After: 0.01950 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01310 seconds
Time After: 0.01976 seconds
Time Taken: 0.00666 seconds
Memory After: 2,261.719 KB
Time Before: 0.02981 seconds
Time After: 0.03007 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03223 seconds
Time After: 0.03348 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03749 seconds
Time After: 0.03768 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04123 seconds
Time After: 0.04271 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=43083' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06139 seconds
Time After: 0.06175 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
