Time Before: 0.01625 seconds
Time After: 0.02446 seconds
Time Taken: 0.00821 seconds
Time Before: 0.02456 seconds
Time After: 0.02509 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02532 seconds
Time After: 0.02545 seconds
Time Before: 0.02656 seconds
Time After: 0.02938 seconds
Time Taken: 0.00282 seconds
Time Before: 0.02553 seconds
Time After: 0.03374 seconds
Time Before: 0.03963 seconds
Time After: 0.03999 seconds
Time Before: 0.04131 seconds
Time After: 0.04250 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03907 seconds
Time After: 0.04266 seconds
Time Taken: 0.00359 seconds
Memory After: 2,261.719 KB
Time Before: 0.06131 seconds
Time After: 0.06146 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07674 seconds
Time After: 0.07798 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.08698 seconds
Time After: 0.08738 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09016 seconds
Time After: 0.09162 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=43115' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10806 seconds
Time After: 0.10842 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
