Time Before: 0.01217 seconds
Time After: 0.01818 seconds
Time Taken: 0.00601 seconds
Time Before: 0.01829 seconds
Time After: 0.01876 seconds
Time Before: 0.01904 seconds
Time After: 0.01918 seconds
Time Before: 0.01992 seconds
Time After: 0.02272 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01924 seconds
Time After: 0.02690 seconds
Time Taken: 0.00766 seconds
Time Before: 0.03247 seconds
Time After: 0.03286 seconds
Time Before: 0.03535 seconds
Time After: 0.03760 seconds
Time Taken: 0.00224 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03178 seconds
Time After: 0.03779 seconds
Memory After: 2,261.836 KB
Time Before: 0.05472 seconds
Time After: 0.05492 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06970 seconds
Time After: 0.07099 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.073235988616943
Time Before: 0.07958 seconds
Time After: 0.08022 seconds
Time Taken: 0.00064 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08311 seconds
Time After: 0.08497 seconds
Time Taken: 0.00186 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789112554, location = '/forums/private.php?do=newpm&explain=1&u=43158'
Time Before: 0.10308 seconds
Time After: 0.10334 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.10207486152649 seconds with 9 queries, spending 0.01028299331665 doing MySQL queries and 0.091791868209839 doing PHP things.
