Time Before: 0.00231 seconds
Time After: 0.00353 seconds
Time Before: 0.00360 seconds
Time After: 0.00444 seconds
Time Taken: 0.00084 seconds
Time Before: 0.00474 seconds
Time After: 0.00490 seconds
Time Before: 0.00570 seconds
Time After: 0.00780 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00496 seconds
Time After: 0.01137 seconds
Time Taken: 0.00642 seconds
Time Before: 0.01393 seconds
Time After: 0.01450 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01699 seconds
Time After: 0.01815 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01322 seconds
Time After: 0.01834 seconds
Time Taken: 0.00513 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.02384 seconds
Time After: 0.02403 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.02633 seconds
Time After: 0.02756 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
Time Before: 0.03105 seconds
Time After: 0.03125 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.03349 seconds
Time After: 0.03492 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
UPDATE session SET lastactivity = 1772859053, location = '/forums/private.php?do=newpm&explain=1&u=43181', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04808 seconds
Time After: 0.04840 seconds
Memory Before: 4,912.180 KB
Memory After: 4,912.391 KB
